When it all goes BANG!
It was nice talking to you today Jeff. Hopefully we can get me squared away.
How  do you know the tensioner failed first.
Its possible the valve broke and caused the tensioner to fail.
I dont think there's any way to know for sure.
I don't know the exact number of hours but not very long. I will definitely replace with an APE manual tensioner.
how would having a valve break cause a tensioner to fail ?  If a valve breaks, and the tensioner is working, it just keeps on spinning the the cam sprocket and camshaft.. if a cct fails, stuff starts hitting that should be.
I am confused by this... don't get what you mean?
Do you run high speed in 4th often and chop the throttle?
pow right in the kisser
every 4 stroke ive ever had gets a manual tesioner off fleabay
I wouldn't say I do it excessively. In this case, I remembered I had some slower riders behind me so I slowed down to check on them.
How would it bend one intake, but not the other not be touched at all? I bet the intake head popped off, then a cycle later the exhaust starts to open, broken valve head smashes into the exhaust valve, destroying the chain/tensioner.
Edited by Lead Head
Valve failure for sure, that sux.
Or whoever assembled the head didn't get the locks in right so they popped out, liberating the valve.
Is that an OEM titanium valve, aftermarket titanium valve or a stainless valve? My bet is the latter...
Edited by Eddie8v
looks like the other intake valve made contact with the piston also, can see the outer edges look alittle cleaner or shinier. If there was more pics that showed the top of the piston it would be easier see if there was contact.
Nah, that's too perfectly clean all the way around the valve to be from piston impact...
Edited by Eddie8v
Right, it does look cleaner around the edges because of V/P contact even though the photo isnt real clear in that area . Its easier to see on the piston top but the same thing happens to the top of the valve where the two parts made contact.
Theres not much carbon build up on the head and valves, can tell it was installed not long ago.
Edited by TDW
