drz400s countershaft sprocket cover
I just installed a 16t front sprocket and I ground down the case saver to make it fit. Just curious if there is an aftermarket cover that fits with a 16t sprocket?
Nope. You have to take the one that fits a 15T and grind.
The stock plastic cover will fit with the ground out case guard for the 16 tooth just fine.
Cool thanks.
