Compression Change CRF250R
If i change from 12.5:1 ratio to a higher ratio will i have to adjust anything else on the bike? I ride a 2005 Crf250r. Any and all help would be much appreciated.
A better question is why are you interested in boosting the CR?
However, usually a slight change in CR only requires a slightly higher octane fuel.
Typically, the boost in performance is insignifivcant yet the additional expense of the CR change along with the pricey fuel makes it a bad idea.
