DR350 Wiseco kit and bottom end
My DR350 came from PO with a Wiseco kit, the 441cc.
also came with a case that had been damaged and repaired, and a handful of other issues.  I've fixed most, and its running fine, but it still leaks oil from somewhere i can't quite determine yet, and with that repaired case i'm inclined to just buy a used bottom end for some piece of mind, and in the process maybe find/fix the leak(s).   And probably do some clutch mods, etc.
Any concerns I should have about mating the Wiseco piston setup with a new (used) bottom end?  I can't imagine, but who knows...
