Bad clutch cover gasket= Catastrophe
This is the result of a clutch cover gasket that started leaking coolant while riding. It is on a 2011 KTM 250sx. Genuine KTM gasket that was changed 40 hours ago has failed again. The first time I changed it was because it was leaking transmission fluid. This time it leaked out the coolant, causing the head to get extremely hot and melt a head o-ring. Which created enough void to let the combustion exit through. End result is a cylinder and head that have a hole pierced through them. Going to replace gasket with a cometic and cylinder with a 300sx kit. Kind of a bittersweet deal.
That sucks man, sorry to hear that. Did you get any signs something was amiss? or was it wam bam I just ruined my head and cylinder?
Running lean was the only sign. I had rode for 2 hours without anything noticeable. I knew something was up by the way it would over rev at idle but had no choice but to keep going. I was solo in some rough country. Pushing it out was not an option. I was even turning the choke on and off to try and keep it wet. Within 15 minutes it was done.
i guess you havent taken one apart. water pump is part of the clutch housing which sends the water through into the cases. junction between cluch housing and cases is where it leaks. its hard to say a exact reason for the leak. most people dont use torq wrench or tighten in a cris cross pattern so its likely many people are under or over tightening the bolts and by not using a proper tightening pattern they  not getting even pressure on the gasket. but what ever the reason, ive had good luck with stock gasket and sealer. but even then you still need to use correct torq and proper tighteneing patern. not everyone is cut out to perform mechanical work and im certain thats where a majority of the problem is
Na... Its a weakness. The pressure of coolant the complexity of the gasket, the thinness of the casing at the front... It all adds up to a weakness.
You cant blame peoples skills when the origional goes (sometimes very quickly)
so im getting ready to change out my gasket to the cometic one . is there any specail tools i would need or anything to watch out for.
