offworlder Posted September 8, 2013 With a tip of the hat to a similar thread on the ADV forum, what did you do to yer beloved Beta today ? I spooned on a fresh MT43 (yum !) and attempted to bump up to a 50 tooth in the rear. I was disappointed to discover the chain was not long enough to accommodate the 50 tooth - and had to revert to the heavily worn stock 48 tooth sprocket. As my chain still has plenty o' life in it, I'll order me up a IronMan 48 tooth, and bump to the 50 when the chain needs replacin' . Quote Share this post Link to post Share on other sites
thebob_za My Rides (4) Posted September 8, 2013 New fork bleeders and going back to stock footpegs. The aftermarket ones were ripping my boots to shreds Quote Share this post Link to post Share on other sites
BassMan Posted September 8, 2013 (edited) Fresh MT16s, wow didn't realize how much those stock tires really sucked , FIM enduro rated tires for the first and last time ever Also the renthal brake pads are worlds better than the nissans. Edited September 8, 2013 by BassMan 1 1 Quote Share this post Link to post Share on other sites
DALLASDRZ Posted September 8, 2013 Got some new tires and installed seal savers, pulled carb out for cleaning and replace the pilot jet. 1 Quote Share this post Link to post Share on other sites
redpillar Posted September 8, 2013 I checked by wheel bearings and am going to change the fork oil. Any recommendations? Also replacing the front brake pads. Quote Share this post Link to post Share on other sites
ballisticexchris Posted September 8, 2013 I'll tell you what, the Race Tech oil is some really slippery stuff. Expensive but well worth the dough. If you have the 45mm Marzocchi's it takes about 600cc per leg or 100mm. As far as Brake pads I like the EBS Red Organic. Easy on the discs and great brake modulation. The drawback is that they don't last as long as the sintered ones. Quote Share this post Link to post Share on other sites
redpillar Posted September 8, 2013 Thanks Chris, They are 48 mm Sachs on mine. It would be nice to have an exploded view of them but can't seem to find one anywhere. I should be able to get some Race Tech oil from the suspension guy around the corner. Quote Share this post Link to post Share on other sites
motoxgiant Posted September 9, 2013 Bolted on a 50T rear to match to the new 13T front and Regina chain on my 250RR. Goldilocks gearing for the woods of Michigan - not too tight, not too loose, just right! Quote Share this post Link to post Share on other sites
weantright Posted September 9, 2013 (edited) Thanks Chris, They are 48 mm Sachs on mine. It would be nice to have an exploded view of them but can't seem to find one anywhere. I should be able to get some Race Tech oil from the suspension guy around the corner. Last page http://www.americanbeta.com/sites/default/files/images/partsbooks/2012_SHIVER_48_40_Manuale_ED00_2012_12_18_00.pdf Not all advertised weights are the same. Find the same tested weight to brands so you don't need to reset your settings for the same performance. http://www.peterverdone.com/wiki/index.php?title=Suspension_Fluid Edited September 9, 2013 by weantright Quote Share this post Link to post Share on other sites
redpillar Posted September 9, 2013 (edited) Thank you, but that file is for the Marzocchis. I have Sachs forks. There is a bit of a service section in the bike manual, it would be nice to have something like the Marzocchi manual for them. Edited September 9, 2013 by redpillar Quote Share this post Link to post Share on other sites
weantright Posted September 9, 2013 How about this http://www.lt-racing.com/html/sachs_48_fork.html Quote Share this post Link to post Share on other sites
redpillar Posted September 9, 2013 Cool, thanks that is basically the same except for the fork cap, and the rebound adjuster looks different. I hope mine did not have the little ball bearings in it because I don't see them now... Quote Share this post Link to post Share on other sites
ballisticexchris Posted September 13, 2013 (edited) Oil and filter change. Motul 300V 15-60, Transoil Expert. Checked air filter, went through all my bags, new rear tire Kenda Trackmaster 110/100-18, flipped front tire over Kenda Trackmaster 80/100-21, lubed chain, changed gearing from 14/48 to 13/48 for single track ride Saturday. Ready for the next flogging! Edited September 13, 2013 by ballisticexchris Quote Share this post Link to post Share on other sites
Donjholt Posted September 14, 2013 Initial break in oil service, re sprung for my size and race tech gold valves. Cleaned air filter. Quick little rip around the lot and I was in awe. First bike I have ever had sprung for me and I will never own another bike without it being done. Tomorrow will be awesome. Rain most of the day 3 Quote Share this post Link to post Share on other sites
hawaiidirtrider My Rides (6) Posted September 14, 2013 (edited) I went riding. We didn't go real hard but we didn't stop much..My buddy took his 01 cr 250 and I had my 09' 525 RS... 2 guys and we had a good rain so we were slipping around here and there and had a couple of flops on some slippery hills. ..just picking up your bike can tire us out a little. I had a nice hand cramp driving home. ..but it was a great session. 10AM to 2PM..and not stopping much.. good one!! 👍 Edited September 14, 2013 by hawaiidirtrider Quote Share this post Link to post Share on other sites
thebob_za My Rides (4) Posted September 14, 2013 (edited) Rode the wheels off mine today in the sand. Great fun Edited September 15, 2013 by thebob_za 4 Quote Share this post Link to post Share on other sites
glangston Posted September 14, 2013 Oil change, and filter. Pretty exciting....no leaks.😉 1 Quote Share this post Link to post Share on other sites
DALLASDRZ Posted September 14, 2013 Got the bike back together today. Fresh air filter, routed two up carb vent lines to filter in air box, used heat gun on IMS tank to get a little more fan clearance. Ready to ride! 1 Quote Share this post Link to post Share on other sites
ballisticexchris Posted September 15, 2013 Trashed the shit out of mine today. Steep, massive, rock gardens. Flipped and launched the poor thing more times than I can count. As an added bonus I broke the right foot peg, banged up my sweet LEO Vince muffler and cracked the end cap. I was wondering how come my toes hurt so much at the end of the ride. LOL I took this bagged up beast up some stuff that would have me crying on my 300. FWIW Even after flipping it and dropping it numerous times, it fired right up each and every time! 3 Quote Share this post Link to post Share on other sites
hawaiidirtrider My Rides (6) Posted September 15, 2013 Trashed the shit out of mine today. Steep, massive, rock gardens. Flipped and launched the poor thing more times than I can count. As an added bonus I broke the right foot peg, banged up my sweet LEO Vince muffler and cracked the end cap. I was wondering how come my toes hurt so much at the end of the ride. LOL I took this bagged up beast up some stuff that would have me crying on my 300. FWIW Even after flipping it and dropping it numerous times, it fired right up each and every time! Good thing you had all those bags.. That probably protected the bike a little.. breaking off the footpeg!!!! OUCH!!! Quote Share this post Link to post Share on other sites
