offworlder
What did you do to your Beta today ?
2,493 posts in this topic
Posted (edited)
Hopefully I didn't just post this 3 times
Edited by basalt
1 person likes this
I just rode for a week in Colorado with the standard version with one puck. My observations: awesome product, I actually found myself standing to relax the pressure on my hands. I tend to grip too tight in the gnar and the pegz allow almost no grip pressure in the standing position. A couple of problems: One is the light gauge steel on the standard pegz bends easily. Sometimes it was a subtle bend that was only noticed when one boot wouldn't engage. Easy enough to bend back. Second, with one puck when your boots are wet there is no grip. Not the end of the world but noticeable. For me the perfect set up would be two pucks with dessert king frames.
I think this would still allow standing.
One unexpected benefit for me was that the increased attention to controlling / feeling the bike with my legs caused me to have much better control of the bike on long off camber side hills. This may not sound like a big deal but there were many times in CO that losing your line on a side hill has dramatic ramifications. In many situations confidence was the difference between crashing and making it through. All in all, this mod has made more of a difference than many of the mods I've spent money on and has made me a better rider even when I get on a bike that doesn't have them.
Sent from my SM-G930V using ThumperTalk mobile app
3 people like this
Installed new Renthal Fatbars on the 300rr today. As mentioned previously, I had a little incident where the bike ended up cartwheeling down a short hillclimb. Anyway, I order the closest bars I could find to the stock Beta bars...I'm pretty particular about bar setup... a tall bar position makes it hard to get into the attack position and I have nerve issues with my left hand, so lot's of sweep puts my fingers to sleep.
1 person likes this
Posted (edited)
I didn't do anything to it but leave it dirty and still loaded on my van.. I thought I was riding today but my friend backed out of riding.. It's still on just in case I can get a ride in   in the morning.. or later ..
 It's actually not that dirty or as bad as other muddy days..
Edited by hawaiidirtrider
3 people like this
Are the stegz required to be removed for Air Filter service?
Yes, just have to remove the upper bolt then swing it down enough to pull the air box cover.  I love mine too and it's totally worth the extra 30 seconds it takes to open the airbox.
1 person likes this
3 hours ago, hawaiidirtrider said:
Did yours break?
Yeah, in the same incident as this:
None of the good stuff happens when my riding camera is on.
1 person likes this
Don't say that!!! I'm going to have to stop taking vids.
I can replace the filter without removing them however, like DWT says you can pop the top or bottom bolt and they swing clear to make it easier. I definitely don't move it to take the cover off, mine will just slide out. I do swing it out of the way to change the filter. I have actually got the filter in and out without moving them, but it's not worth it. The pegz are worth it.
1 person likes this
Hey HDR, which Seat Concepts seat is that?
  • Similar Content
    • By markwoodlief
      anyone running the g2 throttle tamer on their 4t bikes? Just picked one up today. I have installed them in the past on both my KTM and my Hsq 501. But with the beta there seems to be too much side to side play between the throttle and throttle housing, allowing the cable to move in and out of the grooves. I can hear my cable grinding as I rotate the throttle. Any clues? Wondering if g2 was just getting to market quick, since our throttles are basically a KTM 50/65 2t cable, and just put Beta on the sticker.
    • By sasrocks
      The Beta 250RR is a premium Italian enduro bike with a slightly lower seat height than KTM and excellent handling and power. The 250 has awesome low end torque and still revs higher than a 300, allowing for more usable range of power and actually less need to short shift the bike. Plus it has less rotating mass in the engine so the handling feels more nimble. Design features and mods of this very clean well maintained bike:
      Electronic Variable Oil Injection design, no mixing of fuel required! The oil tank holds enough for up to 3 tanks of gas.
      Dual Ignition Map soft and hard power curves
      Adjustable Power Valve; can completely change the power characteristics from linear to a distinct hit (which is easy to predict and ride thru). I have the soft map + distinct hit tuned via the power valve ( a simple hex head bolt adjustable without removing any cover). This combo makes for plenty of grunt in the woods, but not so much that the throttle is jerky. then when the trail opens up you have the awesome power up top when the power value opens up.
      Suspension revalved and resprung by Stillwell (The Beta experts) for 190 lb rider.
      Rekluse 3.0 Core EXP Clutch: top line of the auto clutch, is a magical addition that makes any ride better. can still use clutch manually to pop over obstacles etc.
      Full off road protection:
      Aluminum Pipe guard
      Acerbis Hand guards
      Rear disk guard
      EE skid plate
      BRP radiator guards
      Clutch Slave guard with brush bar
      Ox Brake Left Hand Rear Brake; simple cable system to operate brake with foot or hand
      Beta Fork Bleeders
      Larger kickstand foot to not sink in the mud
      Goldentyre Fatty front tire; unmatched traction
      Shinko 520 rear tire; recommended with Tubliss system
      Tubliss system Front and Rear: dramatically improves traction; can run much lower pressure safely and maintain much better flat protection, also with lighter weight than HD tubes. You can run safely on a flat tire back to the truck due to this design
      PLUS: Registered and Plated in Missouri. Along with the oil injection you can dual sport this bike and fill up along the way without having to mix oil. It will maintain 65 mph with stock gearing and still crawl in the technical sections. (lights removed currently. Horn retained so you can honk to alert slower riders in the woods )
      All Extras
      Stock skid plate, DOT Michelin tires
      (oil tank currently removed)
      Bike is maintained regularly. Steering, swingarm and linkage bearing greased with Bel-Ray waterproof grease. Fresh Rotella in gearbox. No Toil air filter oil used. Extra Twin air filter included
      Parts are reasonable and very easy to get. 285 miles, 18hrs
      This bike is ready to roll: race, trail or dual sport. It is set up perfectly and better than new with Rekluse, suspension, Tubliss LHRB and all the protection parts.
    • By GerGa
      For sale is a BRAND new 2017 solid white 6D ATR-1 helmet.  Size medium.  I had my local shop order one for me thinking that it would fit because I tried one on last year.  I don't think my memory served me well or I tried it on long enough because it doesn't fit my head and a little big.  Just over a month old and only warn 10 minutes in the house.  I can't return it because they ordered it for me.  Shiny and new.
    • By kbro45
      I recently fitted my 300rr with Flexx bars and noticed the brake line fitting would rub on the bars.  I was pretty limited in what position I could run my master cylinder.  I did a search on here and found that some people had tweaked the brake line fitting.  Before I ever had a chance to try that I noticed I was getting a very slow leak around the banjo bolt which I assume was from the fitting being pressed up against the bars.
      I ordered a Core brake line off ebay (listed for 2015 300rr).  The fitting on this brake line is bent a little differently and provides much more clearance.  The line is also custom made to order so you get to choose the color of the different parts of it for a little extra bling.
    • By gaortiz
      Preordered my 2018 500-RR-S yesterday! Time to start buying parts! The bike should be at my dealer the first week of September!
      So far my parts list is below. Feel free to suggest additions!
      Cycra hand guards,
      front disc guard,
      rear disc guard,
      slave cylinder guard
       rad guards,
      rad hoses,
      3 gallon tank
      Hyde skid plate
