offworlder
What did you do to your Beta today ?
2,643 posts in this topic
Yesterday...bolted up the TM designs skidplate and of course the new suspension. Stillwell-tuned shock with the bladder kit and CC Sachs revalved/sprung with different ICS springs as well. Told them I wanted the closest I could get to my 300 with CC 'Zokes and a Fox podium.
5 people like this
On 12/31/2017 at 9:00 PM, pineapplebrah said:
Tried out a set of Emperor Racing mounts. Little did I know that it blocked access for the key. Anybody install a toggle switch in place or eliminate the key switch?
Why did you put those on?  What hand guards are you going to use?
1 person likes this
Mainly to clean up the bars. I'm using G2 handguards. Just ended up cutting down the key. Works fine.
1 person likes this
I replaced my stock rear for a new MOTOZ hybred gummy...very sticky !
Very cool, I liked the past MotoZ hybrid I ran, now when you need a front try the MotoZ extreme hybrid 80/100-21 I’m digging the heck out of mine especially with Tubliss.
I think the front i'll get is the fatty golden tire. It sounds like a great tire.
You can save some money with a shinko mx216, which is the same tire (you can do a little web search to verify).
3 people like this
I wish shinko had designed these copies with the NON FIM height knobs. While I like the goldentyre 216 type tires in the rocks, the utter lack of sidebight round the terms turns me off from them. I might get the shinko and a moose and see if it truely is designed for low pressure. I felt them sliddy in the turns.
1 person likes this
It's my understanding that shinko didn't do any design work on these as they are the same molds used to make the goldentyres (which shinko actually made on contract - I get the impression goldentyres is a design company and not a manufacturer). So, they are not shinko designed and they aren't copies. I haven't gotten one yet as I've got the original goldentyres branded one and they last pretty well. I'll be doing one soon though as I've got a new tubliss setup and need a new tire to go with it.
Does the knob height not bother you? My stock beta 300 tires felt like they had no side bite. I guess if I ran them down around 5 psi, similar to having a mousse they would perform better but A. I don't want to run mousse's because money, and B. I can't run tubes that low in new england. So the tire just doesn't work for me.
You are talking about the front tire? The only Shinko 216 I've found for sale is the front. Either way, I haven't had an issue with the Goldentyres (and now front Shinko) and side bite while turning. I'm back to a m5b evo with a mousse on the back, but only because the evo last longer. The stock Michelin have much smaller lugs and are a horrible tire in the dirt. I could live with the stock rear until it was worn out after 15 hours, but the front came off after 1 ride...my complaint of my '18 350 knifing in on turns was completely tied to the front tire. The Shinko mx216 fixed everything.
2 people like this
https://www.shinkotireusa.com/products/off-road/extreme-enduro
SX216 Rear in 140/80/18
I haven't had an issue with it but we may have different cornering styles. I know the terrain you're talking about (I've ridden in central mass) and the stuff I ride here is rocks. I currently run 9psi in the front goldentyres 216 fatty with a BS ultra HD tube. I've done the shinko cheater and now have a kenda equilibrium on the rear (I ran these on my old kx250 too).
It wasn't cheap, but I finally broke down and bought the Motominded Baja designs Squadron sport. It's only the 20w, but I think even that's something like 2200 lumens. Anyway, it's freakin' bright...I'll probably get the Squadron Pro for the 350 as it can support a higher wattage light.
Edited by Sierra_rider
3 people like this
KYB forks I bought off another member on BetaRiders, new CS sprocket and DDC rear sprocket, primary drive chain. Also switched back to the stock carb after messing around with the Lectron. National Hare and Hound next week!
1 person likes this
Any issues with the 'zokes?
  • Similar Content
    • By deanmellor
      My top end went on m 98 cr 125, the needle bearing clip came out and broke apart and shrapnel got everywhere and blew it up. I cleaned out the top end and washed out the crank with the bike upside down. the bike starts up great and seems to run fine but im getting a weird di-di-di-di-di-di-di noise coming from the motor. i tried adjust the power valve and tightening everything but the noise is still there. Here is a link to a video where you can hear the sound. It gets louder as rpm's get higher and at really low rpm barely idling it goes away. I am pretty new to bikes and 2 strokes so any help would be appreciated.
      https://youtu.be/msfU8WCXg8E
    • By RidingWithStyle
      In need of Cycra Handguards (probends) for my bike. Need 1 1/8 clamp size for renthal twinwalls. Message me if you have any for sale at a good price!
    • By Baja Designs
      Hello CRF450R Owners,
      Bailey here with Baja Designs.  We recognize ThumperTalk as one of the go-to sources for information on the CRF450R and we receive emails daily regarding the best inexpensive light setup or purchasing the B1K setup ran by Ox Motorsports.  We would like this thread to be a General Discussion area for members and guests to discuss Dual Sport Kits (DSK), Lights, and Lighting Acessories based upon stock and modified charging systems.  Please Post up if you have any questions or comments CRF450R related!
      www.bajadesigns.com
    • By WheyNic
      Was wondering which is the best street legal enduro bike in your opinion. Want to see different opinions since I'm new at this. Details appreciated.
      Thanks
    • By BetaDale
      I had been considering for quite a while this preload adjuster, but the price put me off.  I saw it listed on Amazon, so threw it on my wish list at $154, free shipping + tax.  I received a notice a couple weeks later that price dropped to $146 + tax, so I pulled the trigger and ordered it.  I did a little research on best way to pull the shock.  I removed muffler, unbolted top of shock, disconnect bottom linkage from frame/shock/swingarm but really only needed to remove at frame and shock, and pulled shock out at area right side of bike near airbox boot.  It was tricky but got it in & out through there.  Had to use ratchet strap to compress spring to get locking ring back on bottom of shock with Xtrig installed.  It really works slick and I’m happy with it! I measured the spring compressed with shock removed & used this as starting point when going back together once Xtrig was installed.  For 16 500 RS, I ordered XTRIG 500010800101 Shock Pre-Load Adjuster.  Amazon wish list is pretty handy!
