is 2005 kxf250 triple clamp compatible with a 2005 kx250 triple Clamp?
hi all
is 2005 kxf250 triple clamp compatible with a 2005 kx250 triple Clamp? will the forks swap out swell.
cheers
nick
They are both kyb, but the 250f has bladder OC forks and 250 has the TC forks. The probably wont swap, but im not sure. You are trying to put the 250 forks on the 250f, right? Its kind of silly to do it the other way around.
Look on the Kawasaki site to compare the part numbers, but the clamps fit the same.  Just look at any aftermarket clamps for those years.
