1987 TRX 70 bypass ignition key?
Honda
My dad just pulled my old TRX 70 out of storage so I can get it up and running to teach my son how to rid3. Problem is, we dont know where the keys are. Is there any way to bypass/remove the ignition?
If you go under the plastics and remove the key you should be able to jump the ignition with a copper wire. Sometimes removing only the ignition itself will do the trick.
Get a key made at most any Honda shop.  There is a number on the switch, give that to the dealer and they can cut for around $5.00.
Had to do that on an 87 trx125 someone gave me.
