2007 RMZ250 Wont idle
I recently picked up a 2007 rmz250. The bike will run at 1/8th throttle but will die as soon as you let off the gas. Choke wont stay on and it backfires a little.
I took all the slack out of the throttle cable and even turned the idle screw to the max and it still wont idle.
I messed with the fuel screw on the bottom a little and it seemed to help it run smoother (about 2 turns out) but still I can't get it to idle without holding down the throttle.
I also cleaned the carb and made sure the jets weren't clogged. While reassembling the carb,  I overtightened the decompression screw on the carb and it broke off inside. It took some time to get out but its out now and have a part coming in the mail.
This bikes really starting to seem like a bad idea
Someone please help me
Check the air filter and housing for dust, dirt, and debris. Also check the spark plug.
Put slack back in the throttle cables.
Buy a new choke knob.
Ensue all carb passsage ways are clean.
Buy a brand new pilot jet.
Fine adjust the fuel screw when the engine is hot.
