Spring rate balance option
I need to change de spring on a KTM 150SX for a 120 lbs women
Racetech sudgest
.412 kg/mm fork spring
4.53 kg/mm shock spring
I can get this one for the fork
.41 kg/mm factory connection
.42 kg/mm racetech
For the shock the lightest I can get is the Factory connection 4.6 kg/mm
My question is, should I go with the .42 fork spring to keep a better balance between the front and rear, or the .41 to be close from their recommandation ?
somebody ?
What year?
What's her speed and riding discipline?
MX track, C women class, 2013
My concern is mostly about the balance
With the 4.6 kg/mm shock I'm .7 heavier than the sudgest rate
So if I take the .42, I'm .8 heavier, so this is really similar from the rear difference, but with the .41 I won't get this balance
It's been my experience that racetech's spring rate "SUGGESTIONS" are a little light. On their website they say to use the closest rate spring. I always go to the next heavier rate. I'm not a suspension expert, but I think you would be fine going to the heavier rate - .42
Personally, I prefer a heavier spring and lighter valving. It keeps me higher in the stroke, and I feel encouraged to go faster. I feel the heavier spring is slightly more forgiving for those times I come up short or over jump....
JMHO.
I like your way of thinking, I also think a lot ride their bike with stock suspension spring and come used to ride with heavier spring so the transition is easier
Yup, .42s is what I would be running....
Good thank a lot
