Pinging?
Hi im just wondering what is pinging on a 4 stroke motor. i see that word eerywhere and have no clue what it is
most of the time people dont know the diffrence between pre-ignition and pre-detonation. both make a shart sound that sounds like it is metal on metal contact. call it "pinging" think, hammer hitting an anvil.
Detonation: Detonation is the spontaneous combustion of the end-gas (remaining fuel/air mixture) in the chamber. It always occurs after normal combustion is initiated by the spark plug. The initial combustion at the spark plug is followed by a normal combustion burn. For some reason, likely heat and pressure, the end gas in the chamber spontaneously combusts. The key point here is that detonation occurs after you have initiated the normal combustion with the spark plug.
Pre-ignition: Pre-ignition is defined as the ignition of the mixture prior to the spark plug firing. Anytime something causes the mixture in the chamber to ignite prior to the spark plug event it is classified as pre-ignition. The two are completely different and abnormal phenomenon.
oh i get it now and this happens by fuel mix? octane?
Pre-ignition happens because octain level in the fuel is not high enuogh. for the most part. tuning of the motor could play a part in it as well. this can happen on 2 and 4 strokes.
