Hard to start
Well I have a crf250r 08 for a while and it had been starting fine Until a week ago when it started to be a bitch to start, I check the valves a liltle while ago but I'm going to check then again soon. It's very hard to start cold and hot when it was fine before, it roll starts piss easy which is good and it doesn't idle properly, I personally think that their is stuff in the carb and it needs a clean out and tune or the valves need to be adjusted. Any opinions??
I would start with doing both of those things.
Yeah when I get time I'm going to do. I think it's the carb because It went hard to start just instantly didnt do it slowly just out of no where
On my 06 was the same way. Just one day couldn't kick start it. Valves were spent. usually starts with the right intake valve ten goes from there. But never hurts to do process of elimination. Good luck
checked my valves and both the intakes are out and im going to shim them soon and see how the bike goes
I shimed my valves and the bike starts and runs good now :)
Edited by Rollzy
hate to drop the bomb but you may get 3-5 good rides after the reshim and then its time to rebuild the head
yeah I know that so I'm getting a kimblewhite intake only kit that comes with the valves and springs and retainers and seals... Ect. And I'm also going to get a new piston and rings for it while I'm in the engine
might be a good idea to change out the timing chain while its down
Yeah I might give that a go too
