Clutch issue on my son's bike
I recently bought a 2004 65sx for my son.  The clutch seemed soft but worked fine for a month.  The other day the clutch wouldn't disengage at all and would just die.  There was no fluid in the reservoir so I bleed the clutch and it worked for one day.  the clutch went back to not disengaging and the fluid is all gone.  I don't see any leaks around the line.  Any ideas where I should look?
Thanks
Jared
Have you checked to see if the secondary cylinder is passing fluid? If it's not leaking on the outside it has to be on the slave cylinder
