Leak in crank case help
I noticed the my bike, 2000 kx125 was leaking tranny oil from the inner clutch cover case so I put a new gasket in, filled it up with oil and it started leaking again... Help please!
Sometimes when using a razor blade you gouge the case. If so, the oil is bypassing the seal because the seal does not aitting properly. As a last resort (and temporary fix) I would get some high temp silicone like and put a thin layer where you suspect the leak is coming from.
For future reference or anybody reading this- dont use a razor blade. You could also try the tube gasket stuff, i had to use some on a different bike about a year ago, held pretty good so far, should seep into any place that was damaged. A tube runs for about $25 and is enough to do all the gaskets on maybe 2 bikes. I wouldn't recommend it as a first choice though
Ouch..
What would u use to clean off the old gasket then, also can you quote this when you reply so I get an email notification! Thanks
Get a can of that gasket remover, I think it is by Gunk.  Spray it on, let it sit and use a plastic or brass scraper.  The aluminum case material is just cast and not very tough.  You can literally shave away aluminum with a razor blade.  That is not what you want to do.  Plastic spackling knife with the spray remover works good.
