520 exc voltage regulator location
I've got a 520exc that's missing it's voltage regulator.  Where on the bike is it supposed to be installed??  I've found the connector but not sure where it's supposed to be mounted.  Thanks
Edited by Omegas
I have a 2002 520 exc.  The stock is normally under the gas tank and 1/2 inch in front of the ignition coil.  I installed an after market included with a Trick Dual Sport kit (years ago).  It was installed inside the air filter box toward the rear of the box.
