Help identifying Athena Cylinder please? Pic!
I tried their website and had no luck with these numbers.
Anyone help me crack the code?
Thanx in advance!
Bike is a 2003 YZ 125, wondering if this cylinder is stock bore or larger....
Thanx in advance!
I know the letter "A" means the bore was set to match an "A" piston.  If you have a metal multi shim type head gasket it's a 144 big bore.
Ehh just an OEM looking paper gasket. Thank you for the help!!
That's strange, Athena either used dual orings (which you can't see as the head sits completely flat on the cylinder) or steel multi-shim gasket. Maybe you have some type of older Athena 125cc kit that uses a single gasket that i'm not familiar with
Yeah I figured it was either a stock/ OEM replacement barrel or pumped up a bit.
Probably had a piston failure at some point. I received the bike with the athena cylinder/ head already on it.
Was trying to avoid cracking it open.
Thanx again!
You are right. I just checked it out and it is a "stock bore" replacement kit for a 97-04. Hope this helps.
Thank you! How'd you locate the info? Sorry for the late reply!
