XR 250 won`t start
My mates 250 will not start.
It ran fine when he last run it about 6 weeks ago and then put it in the shed.
Carb all cleaned out and fuel getting to the chamber.
BUT no spark at the plug, but getting a spark at the end of the HT lead.
Changed 2 different caps and 2 different plugs but still no spark at the plug !!
Is he missing something ????.
Can a weak spark get to the end of the HT lead but struggle to get to the plug ?
Any ideas pls.
Bob.
I've heard this before. carb cleaned, all except for pulling the fuel screw. If you didn't do that , you didn't clean it and bike will be difficult to start.
Depends of how he's checking for a spark.
Fuel screw has been out and all cleaned.
XRs have a tiny spark. This is normal.
I wonder if you have a ground problem or corroded kill switch.
Not to sure it`s just strange that you can get a spark from the bare HT lead when grounded to any part of the engine but not when there`s a cap and plug attached.
OK, there's a resistor inside the cap.  Unscrew internal tip with screwdriver.  You can clean the contacts with muriatic acid and Q-tip.  Rinse with water.  Also replace resistor with brass, copper, or stainless bolt same size.  There's a spring in there, too.
Edited by Baja Rambler
Thanks for your reply.
We`ve done all that you have suggested and have tried a few different caps but still no spark at the plug.
You can cut a 1/4" off the end of the plug wire where it screws into the cap so the cap screws into fresh wire.
Check all your electric. sometimes he kill switch can go bad and stay in the normally closed position not allowing it to keep the electric flowwing. take the gas tank off and check to make sure both leads are still connected to the selonoid.
:thumbsup:
Just to let you guys know it ended up being  the coil.
Now the bike starts and runs better than ever before.
Cheer`s Bob.
