White/blue smoke
Hi all wonder if any1 can help
have a 2002 honda cr 125 kicks over first time and ticks over normally like any 2stroke should however when you throttle up you get smoke which has a slight blue colour to it which covers the air behind you and the bike dies like a fuel starvation problem cutting out and then takes several kicks to re start
i also have an excessive amount off oil/fuel coming from out the exhaust manifold and exhaust its self
have been told that its possibly the gearbox oil seal allowing oil into the engine??
the oil/fuel mix was 125ml 2 stroke to 5 litres off fuel
Thanks for your time
Fitted a new plug to it the other day it run a lot better but still has a lot off smoke
Gearbox oil was a little low but not empty this could may well be the problem???
Yep, could be a problem with a right side crank seal sucking the tranny oil in, and burning it. It will make it smoke, and have lots of spooge from the exhaust. Both symptoms you have. I would drain it, and put in the exact amount of oil needed in the crankcase. Ride it a bit, and drain it, and measure it to see if its close or the same as you put in. A leakdown test would let you know of a seal issue too.
