Chain lube spraying
Where do you guys spray your chain when you lube it? I spray it below the slider and it splashes up against my linkage and gunk just builds up there. I was thinking about spraying it on the chain at the block but it'll just get on the wheels and build up gunk there. What do you guys do?
Under the swing arm, real quick, around the middle, use the straw, and just go around the chain once. It's all it needs, don't over do it, it will make a mess.
I guess i over do it. I spray for a good 5 seconds and i guess thats about 3 times around. I use the straw too but i chop it down to about 1 inch long so i can leave it in the tip of the can and still put the lid on.
I just sit the straw on the chain where it meets the rear sprocket then just spray and rotate the tire till its got one full rotation, thats all it needs and it gives perfect lubing
If its an O rings chain just use a light enough coat of wd-40 to prevent rust and thats all you need.
I personally think wd-40 creates rust because it absorbs moisture, at least everything i put it on turns rusty after a little while.
Its a non o ring DID ERT2
Wd-40 is a water deterant . i spray right at the back of the rear sprocket any overspray using the straw gets on the very back of the swingarm and its easy to wipe it off there unlike linkage
That it is at first, but lets say you didnt ride it for a few weeks its going to look a little rusty.. So it seems like it absorbs moisture in the end.... but this is only is my past experiences
WD stands for water displacing it's not hydroponic   ( attracts water from the atmosphere )
hell it was used on the Altlas missiles to prevent surface rust
definable not the best lube  but works for Me on My chain AZ climate  way better than chain lube flinging everywhere
have not tried this
Edited by Zimman
Amsoil Metal Protector heavy duty is my preference.. sprays a wax like film that displaces water (like WD-40) and dries in place.  Good stuff.
Bike on stand, I turn the rear wheel and spray just below the chain slide underneath the swingarm.. this is the side of the chain that contacts the sprockets.  My father used to merely lube the top side of the chain, but that makes no sense.  Even if the difference is marginal in which side of the chain you lube, why would you not lube the inside of it which connects with the sprocket teeth?  That's what I do.
have not tried this
Ok I got cha, the only thing I dont understand if whats the biggie about the lube slinging around I mean your going to get dirt all over the bike any ways and have to clean the chain off.... just saying
Use wd-40 on your chain since new . just takes minimal effort to keep clean. Use chain lube and all it does it turn into a gummy black mess getting in all the links and wedging it self in the sprocket cavities
the chain lube  i have slings buggers all over and it's thick
I am not alone  many guys use a light oil to keep just the exterior of the links protected and let the OEM grease trapped inside the o  -  x rings do it's job
also the gooy stuff I was using  held sand on the chain   that can't be good ?
This is exactly what I do. Cleaning it well and doing this is perfect for me. Also, make sure the chain is warm when you apply lube: this will make it adhere better and prevent a lot of it from flinging off.
Well even tho the sand or dirt has a easier time sticking to the chain with the heavy lube, still mud and dirt and dust and sand all can stick with lube or without. Its the off road world. oh and yall should get a chain brush makes it easy during clean up and quick if you dont have one
we do have them but its easier cleaning scum off a wd-40 chain rather than a gummy waxy sticky lube
Well I guess the point is all preference
last time I used a chain brush I had o rings fall out
maybe the chain was old  but they fell out due to the action of the grunge brush  so I would rather keep on doing the wd and a wipe down with my 100$ x ring
90 wt gear oil under the swing arm. Once around and done.
