Tube problems
Ok I need some help..got a slow flat...changed the tube...new tube will not hold air when in tire it leaks out from around the valve stem...when I take the tube out and fill it up alone there Is no leaking air??? What is the problem ???
Can you be a little more specific about what you mean when you say it "leaks out around the stem" when in the tire?
Are you sure it's not the air trapped between the tube and the tire that is coming out--thats ok????
