2000 cr125 forkoil capacity
A cr250 uses 328ml for minimum 386ml for standard and 424ml for maximum. Or us oz 11.1, 13.1, 14.3... I always fill mine to the standard. And I use a two stroke measuring cup to determine the proper amount of fuild. The measuring cup is marks with ml or at least mine is marked. But do a web check to ensure the forks on a 125 uses the same amount of fuild. The levels I gave you are for my bike which is a 2000 cr250.
Once you have the forks rebuild and before you install the cap I just pour the oil in.
Hope this helps,
Chris
Hope this helps,
Chris
thanks the web is giving me mixed number and do you pour in the oil when the forks are collapsed or with springs installed
There are videos on youtube that show how. You should also get a manual. It is an invaluable resource to have.
ive been watching vids but my forks are different my oil height tool cant fit because there is a spacer in the way and the manual dosent really clarify to much just height
Edited by markluvsmx
