1985 CR500 CLUTCH NOT ENGAGING
Hi
I have a 1985 cr500 engine i just put into a crf frame.
The clucth will not engage i pull the clutch lever and it is really soft.
I have taken the flywheel cover of and the clutch cable is connected and adjusted fine. I can lift the actuator arm very easy.
Can some one plese help.
Have u thought about replacing the clutch plates aka friction plates
Edited by joethedirtbikerkid
Hi
pull your clutch cover and make sure the nut holding the basket is tight I forgot to tighten mine on my 250 and the same exact thing happened as soon as I tightened it it was good to go
