SM Converted to Offroad , Suspension adjustments?
OK so my SM as been converted to Off road, I'm trying to adjust my suspension but I seem to have a hard time. Can members post there setting to compare the different adjustments between riders who converted there SM.
I'm 200 pounds
Ill bump this. I am wondering the same thing. I haven't adjusted my suspension at all. It seems a bit soft for supermoto but seems alright in woods mode. Maybe the previous owner adjusted it already. What sprockets and chain length(s) are you running for each setup?
I use same spec as an S for sprocket and chain.
I have my dirt wheels setup for a 47 tooth rear. I tried a 44 (stock s) but found it way too high sped for anything even slightly technical. Ideally I would like to have another rear dirt wheel setup with a 44 and more street oriented tire. My knobbies are getting worn out quick just on the short ride to work :(
Tonight I tried with very good results. Forks feels solid compare to other setup I tried (soft and bouncy)
Forks compression: -4
Forks Rebound: -6
Shock rebound: +2 from stock
Shock compression (both) is stock settings
Forks Rebound: -6
It would be helpful to others if you stated those adjustments in clicks out from full IN or HARD.  I'm assuming those are +/- from the factory clicker settings, but which way is + and -?
REPOST
Forks compression: -4 from full hard
Forks Rebound: -6 from full hard
Shock rebound: +2 from stock setting
Note: - is counter clockwise (Soft)
+ is clockwise (Hard)
REPOST
considering that a stock sm shock is much easier to bottom than a stock sm fork  i do not understand how this setup up can work in a balanced way.
i prefer an almost stock shock and a noticeably softer fork (compression 5 clicks from full soft) .
What would you suggest for the rear shock to match the front setting that I have??
i would't try to match that fork setting, imho your fork is way overdamped.
on a sm version i would start from:
fork comp: stock -4clicks
fork rebound: stock
shock rebound: stock + 2 click
shock low speed compression: stock +1
shock high speed compression: stock - 0.5turn
rear sag: 85-90mm
if you bottom out hard (put a zip tie on the fork leg) slowly increase compression (+ 2 clicks ) until you gently bottom the fork only one or two times during a ride.
if necessary repeat the same thing for the rear shock , adding +1click and +1/8 turn at each step
both suspensions should use all the available travel
Edited by 30x26
