99 Honda trx 400ex blowing fuses
My trx 400 keeps blowing fuses when I go to start it how would I fix that?
Check all your wiring for: dirty connections, rusty/dirty grounds, loose terminals on the battery, etc.
First thing you should do is:
Take off the front fenders, and look at the two wires that go into the back of your headlight. one of the wires probably has the rubber coating worn off, so it is bare wire touching metal housing that the wires are running through. If this is the problem, get some electrical tape and wrap them like crazy, should be good to go.
Edited by 110Tim
