Removing Circlip From Gas Reservoir - kdx220 Rear Shock
i understand that the instructions state "..to use a pick or suitable tool remove the circlip from the gas reservoir..", but the circlip looks like it is pretty well embedded into the wall of the reservoir and i cannot pick it out.
any thoughts on how i can achieve this?
i am wanting to replace the actual reservoir itself and the cap with new - as part of the rear shock overhaul i am performing.
thoughts?
byte
The reservoir piston has to be pushed in slightly to extract the clip.
thanks mate.
already done that - depressed by around 20-25mm - with very clear access to the circlip but seems like it has stuck in it's home pretty good - since 1998.
thoughts on how to extract this stubborn cir-clip?
byte
Sometimes you can drill a small hole between the c clip and the reservoir body, Then use a sharp pick to pry it out.
interesting - where in the body should this hole be drilled?
byte
ok - was able to apply more elbow grease and eventually extracted that circlip.
i was also able to extract the original reservoir and cap.
byte
Edited by Byte
