How Do I Remove this Cam Chain Sprocket?
How do I get this off?
Thanks
That's the oil pump drive gear, you have to remove the oil pump on the right side of the engine to undo the oil pump shaft.
I should have said the cases are completely empty, the pic is of just the left half of the case.
I can't get the shaft out of the gear...
Do I just pound it out?
I kinda tried but didn't try too hard.
Edited by arthur6
The shaft is right hand threaded into the drive gear.
