trans swap question
anyone know if a exc trans will fit 08 450 xcf,or any ideas to make a wider ratio tranny,,,,xcw??fit?
download the manual for the exc and xcf see if they have the same lower case..
I swapped my 09 sxf four speed for a five speed from an 09 xcf for they had the same case numbers...Now my old and new bikes both have five speeds...
xcfs have 5 gears,i'm lookn for wider ratio or 6 gears,,,exc has  diff case,has kickstart,can't match gears because,diff ratios,thanks though,d1,just wonderin if gears are interchangable with any ktms,,,exc or xc w
Edited by d1rider
thanks monk,i was hoping the gears might fit,you would think they they would use same type tooling,i know lots of parts on ktms swap,,gear ratios are diff from exc so cross matching would show diff #'s
Their 2 completely different engines... I'm 99% positive it won't work....
hes right your SOL
