Oil still running out of exhaust
Alright new top end right piston and ring. New crankshaft seals and my bike is still dumping oil. I got a 93 yz 125. Idk if It could be a carb issue at this point or not.
Edited by chadster54321
Whats the plug look like? How does it run? Did you measure the cylinder, or just replace the piston/rings?
Had a small engine repair guy do it all. The wrong piston was in it first. It also fouls spark plugs but hasn't so far since I put new seals in. Before that they were covered in oil and black. also its white smoke that's coming out. I even used 40:1 instead of 32 and nothing really changed. Im wary to go any lower.
If it is a 2 stroke white smoke is supposed to come out of the exhaust because of the oil. If it is on the silencer then you are jetted too rich.
If your sure the compression is as it should be (do a compression check to make sure) and it's not burning gearcase oil, the only thing left is your jetting. For the 3457th time, changing your pre-mix ratio will do nothing to correct a rich/lean condition, it has to be done with the jetting. Google "2 stroke jetting" and you will find several very good how to articles on the subject.  :thumbsup:
Not to hi-jack the thread,but whats it mean if it's burning crank case oil? Crank seals? I'm just curious.
I replaced the crankshaft seals
The book says standard main jet size is 330 which is bigger and the jet is 150 yet runs rich? Wtf is going on with this bike?
Have a look at your PV governor if the pin is broken it could be that your PV is not openeing fully
Power valve is fine. The engine specialist looked at that too. I even checked myself
I have a 93 yz 125 and oil spews from the exhaust and floods. top end done by a professional power valve is fine. I jus replaced an oil seal on the crankshaft. I jus now took the carb apart. Needle clip was bent and in 2nd position. I looked at the main jet size which makes me curious. Its 150. Book says 320 a bigger jet. Haven't had the time too take carb completely apart main jet isnt clogged. What could this be? Reeds are fine too. Everything top end related is new.
oil ratio has nothing todo with it.
Use this, it is your new bible. Print it laminate it, buy some jetts for the carb and get that bike running the way it is supposed to
Spanky's Jetting Guide:
A correctly jetted carb makes a tremendous difference in the torque, midrange pull, top-end pull, and over-rev of your engine. If you have never jetted your bike correctly, you will almost certainly gain some performance at some point in the bike's powerband.
A cleanly jetted pilot circuit can be the difference between having to clutch the bike out of a turn or not. The needle can make all the difference in the world for the power of the machine in most situations, as it controls the throttle range that most riders spend most of their time using.
A correctly sized main jet could mean the difference between being able to rev out high enough to not have to shift one more time at the end of the straight, or the power falling flat on top and requiring you to make that extra shift.
Are you fouling plugs? Many people will tell you all sorts of band-aid fixes, from running less oil, to running a hotter plug. Both are incorrect fixes for plug fouling. It's all in the jetting.
The only way to know what jetting changes you will need is by trial-and-error. No one can give you jetting specs, because every bike is different, every rider has a different style, and jetting is totally weather dependent. Unless the person telling you what jets to use is riding an identical bike, on the exact same track, at the same time, his recommendations are meaningless.
Jetting is fairly simple, and is a useful skill to learn if you ride a two-stroke and want it to perform at it's best.
It's very important that you start with the pilot circuit. The reason is simple. The pilot circuit affects the entire throttle range. When you are at full throttle, the main jet is the primary fuel metering device, but the pilot is still delivering fuel as well, adding to the total amount of fuel that your engine is receiving.
Before you start to rejet your bike, you need a clean air filter, a fresh plug (actually you need several plugs to do plug-chop tests for the main jet), and fresh fuel.
One important detail: Make sure the engine is in good mechanical condition. If your engine has a worn top-end, fix it first. Trying to jet a worn out engine is a waste of time. The same goes for reeds that don't seal properly, and a silencer that needs re-packing. Worn reeds will mimic rich jetting, and worn rings will mimic lean jetting.
Before you start the jet testing, Install a fresh plug. Set the float level to the proper specs, an incorrect float height will affect your jetting all across the throttle range.
Warm the bike completely, and shut it off.
As already stated, start with the pilot circuit. Turn the air screw all the way in, then turn it out 1.5 turns to start. Start the engine, and turn the idle screw in until you get a slightly fast idle, or hold the throttle just barely cracked, to keep the engine idleing. Turn the airscrew slowly in, and then out, until you find the point where the idle is fastest. Stop there. Do not open the screw any farther, or your throttle response will be flat and mushy, and the bike may even bog. This is only the starting point, we will still have to tune the air screw for the best response.
Now is the time to determine if you have the correct pilot installed in your carb. The air screw position determines this for you, making it very simple. If your air screw is less than 1 turn from closed, you need a larger pilot jet. If it is more than 2.5 turns from closed, you need a smaller pilot jet.
Once you have determined (and installed it if it's neccessary to change it) the correct pilot jet size, and tuned the air screw for the fastest idle, it's time to tune the air screw for the best throttle response. Again, make sure the bike is at full operating temperature. Set the idle back down (the bike should still idle, despite what you read in the Moto Tabloids), and ride the bike, using closed-to-1/4 throttle transitions. Turn the air screw slightly in either direction until you find the point that gives you the best response when cracking the throttle open. Most bikes are sensitive to changes as small as 1/8 of a turn.
The air screw is not a set-it-and-leave-it adjustment. You have to constantly re-adjust the air screw to compensate for changing outdoor temps and humidity. An air screw setting that is perfect in the cool morning air will likely be too rich in the heat of the mid-day.
Now, it's time to work on the needle. Mark the throttle grip at 1/4 and 3/4 openings. Ride the bike between these two marks. If the bike bogs for a second before responding to throttle, lower the clip (raising the needle) a notch at a time until the engine picks up smoothly. If the bike sputters or sounds rough when giving it throttle, raise the clip (lowering the needle) until it runs cleanly. There isn't really any way to test the needle other than by feel, but it's usually quite obvious when it's right or wrong.
Last is the main jet. The main jet affects from 1/2 to full throttle. The easiest way to test it is to do a throttle-chop test. With the bike fully warmed up, find a long straight, and install a fresh plug. Start the engine, and do a full-throttle run down the straight, through all gears. As soon as the bike tops out, pull the clutch in, and kill the engine, coasting to a stop. Remove the plug, and look deep down inside the threads, at the base of the insulator. If it is white or gray, the main is too lean. If it is dark brown or black, the main is too rich. The correct color is a medium-dark mocha brown or tan.
Once you have a little bit of experience with jetting changes, and you start to learn the difference in feel between "rich" and "lean", you'll begine to learn, just from the sound of the exhaust and the feel of the power, not only if the bike is running rich or lean, but even which one of the carb circuits is the culprit.
The slide is also a tuning variable for jetting, but slides are very expensive, and few bikes need different slides, so we won't go into that here.
Keep in mind, even though this article is intended primarily for two-strokes, four-strokes also need proper jetting to perform right, although they are not quite as fussy as their oil-burning cousins. The only real difference in the two is with the pilot circuit.
Two-strokes have an air screw that you screw in to make the jetting richer, ansd screw out to make the jetting leaner. Four-strokes, on the other hand, have a fuel adjustment screw that you screw in to make the jetting leaner, and out to make it richer.
Thank you. Im am just confused that I have the leanest main jet I can go. The standard is 320 which is more oil possibly coming out the exhaust if I put it in there right? So instead of rejetting it all im trying to isolate the issue the carb also flooded which kept me from starting the engine at all. I'm guessing that rhe pilot jet is off along with the needle clip being bent?
Just a fyi, I suggest you run a clean premix like amsoil interceptor or lucas oil semi synthetic, they are very clean 2 stroke oils
the jets you have don't make much sense, can you get pics of the carb and jets for me plz? something is a miss,
Is it a 15 jett?
stock jetting in that bike goes
330 main jet
15 pilot jet.
6EJ35-59 needle in the 2nd clip position from the top
air screw 1 1/2 turns from fully closed
I think you have them confused, the 150 isnt a 150 its a #15 pilot jet
here is a blown up of your carb,
22 is he pilot stock is a size 15 (use a flat blade screwdriver to remove
23 is the main jett stock is a size 330 (small 5 or 6 mm socket)
http://www.bikebandit.com/houseofmotorcycles/1994-yamaha-yz125-yz125f1/o/m146358#sch147660
23 the stamp on it says 150 I'll look tomorrow morning and I will take a picture of it
That's what happens with the 2 strokers..
This is the 150
