Rear Shock Oil - KDX220
All,
I understand that :
  • viscosity measures the resistance to flow.
  • higher viscosity grade oils have more resistance to flow than lower viscosity grades.
  • oil gets thinner as it gets hotter.
  • to determine the correct viscosity for my application, I need to know the operating temperature of the oil in that application.
  • shocks that operate in high operating oil temperatures require higher viscosity oil.
  • shocks that operate in low operating oil temperatures require lower viscosity oil.
The link below refers to Cst (Viscosity) for suspension oils:
http://www.qemsc.com.au/documents/suspensionoils.pdf
  • Bel Ray HVI 3W has a viscosity of 4.1 at 40 deg C and 12.6 at 100 deg C.
  • Bel Ray HVI 5W has a viscosity of 6.67 at 40deg C and 20.75 at 100deg C.
What are the typical temp ranges this shock would operate in?
What is the impact of having a higher viscosity oil in the rear shock?
Which is the preferred oil for this shock - Bel Ray HVI 3W oil or Bel Ray HVI 5W oil  ?
When is lighter viscosity oil preferred over heavier viscosity oil?
Byte
Edited by Byte
