Crf 250 gear shifter hitting engine casing
I have a 08 crf 250 im haveing problems hitting neutral between 1st and 2nd i noticed the shift lever is touching the engine caseing i have fitted a new shift lever and its still touching im now thinking the shift spindle could be bent looks ok too look at but not sure if the problem could be inside any one had any experience off this
Its very likely the shift shaft is bent. This is a common issue. I would recommend buying a new shift shaft. If the one you have is bent bad enough you may have to cut the end off to get it out.
