Symptoms of burnt out clutch plates drz 400 sm
Help bike runs fine but once its hot its hard to change get when pulling clutch in and when i let it out it bites right away like tgey are sticking. I took the clutch cover plate off and the clutch looks dry well not oiled how it should causing the pressure plate to not let go of the plates . The oil is fine. Changed around 150 miles ago.
Check the clutch hub and basket for notches.
Another cause can be a worn cable/perch/lever.
the cable has done 22000miles so maybe haha
