2013 450sx race sag best setting with ohlins ttx shock
Im 5'8 tall
167 pound 76kg with out gear
ktm 450 2013 sxf
fork springs 46kg
rear shock spring 54kg
Got sag at 99mm static 26mm
ohlins ttx fork carts and shock
Any one running this setup and if so what race sag you set at and fork height
What are your thoughts
Thanks
So there are three numbers we're looking for;
Static sag (35 - 40mm)
Rider sag (100 - 105mm)
Spring Preload.(5 - 10mm)
I'd first start by getting the static sag around 35mm and then check your rider sag. I bet you its pretty close at that point. From there, measure how much preload there is on the spring and I bet you're in the right range.
