Anyone out there with Rekluse Clutch Cover on 07 and earlier WR450?
 just got done installing a Core EXP on my 07 WR450 and the clutch cover is having clearance issues with oil filter cover.   (See picture)
When I talked to Rekluse they said this was the first time they ever had any clearance issues with the WR450 clutch cover. Their fix is to either grind down some of the clutch cover or the oil filter cover. But I am surprised that I was the only one to run into this issue.
Anyone out there have any issues with their Rekluse cover?
I had one on my 2011 with no issues.
Do both dowel pins go into the cover?
Will it fit with the oil filter cover off?
2008 and up have the different oil filter cover than the 07 and earlier WR's.
When I pull off the oil filter cover the Rekluse cover does fit fine.
I ended up having to file down the oil filter cover a little bit around the flat part of the stem that stick out to get it to fit.
The casting around one of the oil filter cover mounting bolts is still really close (less than 1 mm clearance, pic with red circle).
