Lighting on 250 XC 2013
I would like to put a front light on a ktm 250 XC 2013.
I bought the 250 XC-W front light, and pluged it in the plug that is available behind the front fender.
But it is not working, I don't know what to do to make it work, any body knows what I need to do?
Thanks
Do you know which OEM parts from the XC-W I need to order to have the on/off switch?
I though the the light was always one on these bikes.
I found it, on the XC 250 there was 4 connectors behind the front fender. One is for the light, 2 are for a light switch, I have one is for something else. I connected a wire between the 2 for the light switch and the light works right away.
Now I need to find a light switch.
Any one know where I can find a nice light switch?
Check out Baja Designs or Enduro Engineering, they should be able to fix you up.
Turns out that if I order the front fender and front light of a 2014 xc-w it will fit my front front fender.
For the switch I just found an on/off for 10$.
Or you can save $10 & use a twist tie from a bread bag & a piece of orange gum.
I don't know about having it always on. You don't see anything wrong with that?
I take mine off and put the number plate on for day to day riding. Save the bulb and perhaps the Lense from a crash.
