Componts needed to make the drz 485cc? Also how much
Also possible to convert to fuel injection. As wr450 is and wow its smooth as a babys bum compare to the z
Well, you'll need a big bore kit, Athena or the like which will run about $5-700, but do go full out stroker with cams, probably $1400 in parts. As for EFI, no idea on that. Probably $$$$ though to do it properly.
Edited by Unsp0kn
As far as I know there is no FI available for the drz, I'm sure it could be done if you had the $$ but that along with the ridiculous stroker build is straight up dumb money for a drz. If you want a bike like that there are much better platforms than the drz to start on, once you get into strokers the reliability that the drz is known for goes out the window. Sure Eddie built some drz's that make ridiculous power but why don't you ask him for the receipts lol I'm sure it isn't pretty. Is this a track or street bike?
No 522 ?
Fuel injection, sure anything is possible, however, if you are looking for some easily solution, none that I know of.
Isnt there ltz fi?
There was a thread years ago in which Eddie stated he believed he could do an EFI conversion using almost all OEM parts from other bikes. He was willing to try it if somebody was willing to buy the parts. IIRC it was about $2500 in OEM parts at the time.
Isnt there ltz fi?
Yes.
Which would cost a fortune to swap/ convert to a DRZ
And not support serious HP
That’s known as a Lose/ Lose deal
Yes.
maybe its a good idea just to maybe look at going into ktm 450s or along the lines? Would you say thats a better idea :)
485CC done right?
Icecube cylinder
JE forged piston
4mm Stroker crank (or better a 5mm if you can find one)
41mm FCR
RHC cams
RHC over size valves and a quality job installing them
Dyno tuning by a competent operator that knows both the Dyno and tuning a DRZ
Id say unless you are cobbling the system yourself, programming it, building the needed components in house... you’re better off buying a bike you want that has a factory built FI system.
okay thankyou marquez :)
Less money to sell the DRZ and buy a KTM 690. A stock 690 with dirt tires pulled 2 bike lengths on my 434 up to 80mph.
485CC done right?
Icecube cylinder
JE forged piston
41mm FCR
HRC cams
HRC over size valves and a quality job installing them
HRC cams..... Honda cams ?
LOL, no... sorry was sourcing parts for my VTR1000F engine build.... Had HRC on the brain.
Ron Hamp Cycle
 RHC
I believe Craigo485SM (who recently sold his 485) is now looking into buying a KTM..... Talk to him.
