differences between rm250 and rmx 250 (1993)
ok, i nee new crank seals for my rmx250 1993 and i was wondering could the crank seal kit form wiseco that fits rm 250 fit an rmx250??
thanks!!! :ride:
I would say no to using an RM crank seal kit in an RMX, reason being the RMX generally uses a larger ID seal on the flywheel side as the crank is larger on that side to cope with the bigger flywheel.
It's probably best to double check what you have fitted at the moment (the seals should have numbers on them). It would also be a good idea to check the shaft ODs to make sure you order the correct sizes. Bikes of this age may not still be using original parts from previous repairs which can cause problems ordering parts.
