Amsoil
 Is anyone USING amsoil at 100:1 ? Would like feed back from users good or bad
No but I run Elf 2 XT Tech (synthetic) in my Montesa 2T at 80:1.  But the oil, and ratio,  is recommended by Montesa.  Honda owns Montesa and the engine is a 250cc case reed water cooled 2T.
Bad, past idle 100:1 is not enough oil. On gently ridden bikes (not wide open mx) 40:1 is the least amount of oil id run
Bad past idle? Have you actually ran 100:1? Or just your input? I used it years ago in a old gt 800. Never had troubles with it, just wanting feed back from others who have or are using it
Thats silly. I run 50:1 in all my 2 bangers. I have 100 hours on a 96 yz125 motor right now.
Ktm recommends 60:1 in their SX series.
I guess no one has ever ran this stuff
I ran it in an ole' Ktm 300. Ran great actually had over 200. Hours when I sold it. Ik the guy put over 40. More hours after he got it still running 100:1. It never blew on. 100:1. He changed the top end just to be safe.
Amsoil is good .
The Saber Pro 100:1 is labeled "up to 100:1." I mix it at bout 80:1, for my lawn equipment.
The Dominator is engineered for 50:1, follow the label instructions and Amsoil won't let you down.
