KTM 250f 2013 shock reb.
can anyone help me with the correct stock stack?
i have
38.25 2x
36.25
34.25
20.20
36x3.6 stop plate !!!!!!!!!!!!!!!!!
i am not sure about the stop plate,with this stack the shims have only 0.2mm space ( clampshim)
Same what I found on 2013 KTM 125SX and 450SX
rebound shim stack:
38.25   2
36.25
34.25
20.30
34x3.0
rebound shim stack:
38.25   2
36.25
34.25
20.30
34x3.0
20.30 clamp?
in this case the thickness it's very Importand...
20.30 clamp?
Yes, clamp shims were 0.30 mm.
At a reb of 7 it works on hard pack , when in sand its useless , its a single track setting :-(
I done a shock for mogs friend on a 13 bike. He would of felt so much mor control after I'm sure
Look 2:05 - 2:10
Not enough bleed.
I building shock for 16-18 clicks on reb.
Its just my opinion.
Igor.
Look 2:05 - 2:10
Not enough bleed.
Igor.
yes you are right..
i revalve the schock next week.
on the comp i will  make a larger transmission gap (30.1 34.15) and much more hispeed .damping.
also a bleedhole with ~1.4mm
but i am not sure about the reb.
on the bracking bumps and jumps the reb looks fine?
so i can use a 21.3 and the 4 shim reb.
or i can go back to the older with 3 faceshims and so on...
i think with the 21 the stock works also well..
