how to clutch cover 2001 ktm 200 exc ?
i stripped the oil plug hole on the clutch cover and need to put a new clutch cover on.  what is involved in this?  my main concerns are which gaskets/orings to replace, what to put grease on, torques, and what to do with the centrifugal timer does it just bolt on to the new one or need adjustments?  i basically need detailed instructions.  thanks.
don't get a new case. There is another drain plug on the other side under the shifter. Just glue the stripped out one in place with JB weld.
And if you strip both sides you can just lay the bike on its side on a pan and drain through the fill hole. It's a dirt bike. By the way mike it's raining in the hills.
Yep, good ol JB weld.lol
