KX250F Mystery wire
Can some one tell me what the wire attached to the engine in front of the front counter sprocket is for?
that is the neutral switch , supposed to rev limit the bike at a lower rpm so you don't damage your motor.
crap.   I had my stator cover off.   After I put it back on the bike would notyt start.   Prior to tht it was a 1st kick start machine.   I noticed upon inspection that this wire was broken/disconnected and thought it might have been a ground wire.....Back to the drawing bpoard.
If its an FI bike I would fix the wire... My bikes (13 kx450 and 11 kx250) do not like to start in gear hot or cold.
