Marzocchi Shiver 50USD issue
I bought this fork on Ebay listed as perfect fit for kx250f but I'm having trouble whit the caliper mount
Also the pads are way in on the disc, what can I do?
Do you have a OV rotor on the 250f?
yes but any way the stock mount don't fit
distance between holes in the forks are shorter
Obviously the adapter that came with the forks to make them a universal fit was for a regular size rotor.
the forks didn't came with adapter, I have the braking oversize disc/adapter and the stock caliper mount/disc and neither fit in the holes
couldn't find any caliper adapter in the braking website
You should braking directly and see if they have a set up. If the bike that these forks originally came off of used a nissin caliper, then they should have a set up for you.
The oversize rotor bracket wouldnt change the fork. It goes from the stock fork mounting location to the caliper, therefor where the mount attaches to the fork is technically the exact same thing as it would be with no bracket and just the caliper.
The forks aren't a true direct swap if the caliper does not mount up to them. Bracket or just caliper should not make ANY difference at all. This also explains why the rotor is pressed right up against the pads because the hub offset is not correct relative to the left fork tube....
Edited by dmm698
Installed, this forks are amazing!!
needed new wheel spacers and marzocchi caliper mount bracket
Great looking bike, don't get the blue hubs, but thats besides the point.  Where/what is the grip-tape looking stuff on your lower frame called/purchased?
