Drz cam install problems
I just bought a set of stage 2 hot cams and I think I don't got them timed right
I'm reading the hot cams install says there's supposed to be 15 links between the two points(dots)
And it looks like the hot cams are changed again they aren't adjustable and the print says 2013 so I don't think there old stock
And I was wondering how to adjust the cam lashing I got the shim kit
I wrote down all the lashing
Hot cams Says .15mm intake and .20mm exhaust.
Photos will be added
The ones that say 278 312 315 is what came out of the tappets where it says in I think is what should go in
I recently install stage 1 hot cams and I was concerned about the pins between the alignment marks.  I found a post from Eddie saying you don't count pins with hot cams.  Just do a search and you should find it. You need to ensure the alignment makes are correct at TDC.  ie align the 2 alignment marks so a line between them is parallel to the casing and the other alignment mark is straight up.  Both ex and in should be like this at TDC.
Judging by those pics your Intake cam is off, Line up the dots with the head as the others have mentioned.
As for valve clearance, follow the guide that was made on this site.
What clearances do I use the Hotcams or stock?
Where in CA are you?
Jawknee can help you do the damn thang.     :D
Hot cams are ok, OEM are ok....
The more open end of the spec, the faster the valve speed is going to be, and less effective lift (valve opening)
Chico
Got it done
The 15 teeth apart thing was what was confusing me.
Rode it tonight got the cams broke in per the hot cams info
Will check the valve lashing tomarrow and change the oil
Got it done
Whats the break in method they suggest?
See pick
Edited by B S
