Aluminum or Steel Rear Sprocket?
All steel sprockets for me.  I am still saving my lunch money for Big Bore kit.  :ride:
You and I both--Hopefully by spring i 'll have the "georges" to get one!! :cry::rant:
Its not gona make much difference either way.  The weight savings isnt enough that you will ever be able to feel it.  And the low power of this bike probably wont wear the alu sprocket out much faster.  If you dont keep up on chain maintenance then the alu will wear faster.
Basically it comes down to, the steel will last longer.  The alu will give you a tiney bit more performance that you wont even be able to feel.  Take your pick.  Either way it dosnt make much difference.
gnath, is that what you are running?  Where do they sell these to fit the L?  PN#?
I have not bought one yet .......... click on the pic ...  :thumbsup:
I will put a 14 up front with this but, if you do not want to gear it down that low you could go with a 15 up front ...  :prof:
0000-Renthal-520-Twinring-Heavy-Duty-Rea
they also carry a steel sprocket in a 45 for less money ....  click the pic !!!
0000-Sunstar-520-Steel-Rear-Sprocket---.
Edited by gnath9
No 42 tooth.  Bummer.  I was looking to start with the 13/42 combo.
14/45 is the exact same gearing but, would require a nice new pretty gold chain ...  :banana:
Edited by gnath9
  • Like 2
