Having trouble kickstarting
I have a 1999 Yamaha  TT600R, and I am having a lot of trouble kick starting it. About 75% of the kicks result in kickback, like it is advanced in timing or something. I have had it running and it appears to ok once started.
I know how to kick start a bike, and have done so loads of times on other bikes(YZ465,YZ490,XT600,XT500,IT200,Xl250,XR250+.....) without difficultly. (Getting over T.D.C then an almighty kick) I am thinking it is timing related, I have checked the woodruff key and it is fine.
Is there any other reason why it would kickback as often as it does.
Could it be the CDI? I believe it controls the timing of the bike. (I just bought a new CDI for it as the last one was broken)
Any help would greatly be appreciated.
is the decompressor working?
Doesn't sound like it .
Decompressor appears to be working, can see it move and hear it click when slowly kicking it.
Seems to breakdown at high RPM though. So I am not 100% sure where to go from here. :/
Going to checking the timing with a timing light to see if something electrical is causing the timing to be slightly advanced,
What breaks down at high RPMs ?
Valve adjustment/clean carb, or technique
