Chains and tires
Im building a 125 for vintage mx. I didn't realize until I had road raced bicycles the difference small changes in tire size and rim weight made. I could actually notice the difference between a 32 and a 36 spoke wheel
So, what is the lightest reliable 520 chain and tires made?
old 125's are a slight bit heavier then a bicycle
:bonk:
The smallest tire will be the lightest.. like a 100/90-19" tire.  But on a dirt bike, the weight is far less significant than on mtn bikes.  I ride mtn too and a few lbs can make a big difference.
It's an 83 kx125. I know a small tire is the choice . I thought someone might know which brand of tire was lightest . Doubt all 110x19 tires weigh in the same.
Yes clearly when you are the engine on a bicycle, weight can be felt easily. But dont think it doesn't make a difference on a dirt bike.
I had a flat on my WR450 and robbed the rear wheel off my yz125. It was nearly 3 pounds lighter with smaller tire, standard tube and aluminum sprocket . I'm far from being a double digit pro mxer, but I was shocked how much better my bike went over nasty ground and how it accelerated quicker. If there is anywhere to save weight on a bike is anyplace after the linkage and end of the forks. Since I had to buy those items anyway I'd do a little research first.
It's funny now 4 strokes are here wieight isn't such a big issue to magazine testers or riders that buy them.
Back when 2 strokes ruled Moto if a bike was 7 pounds more than another model it was damned to Hell and was unrideable.
Now a 250f is 30lbs more than a 125 no one seems to care
