Will ice expanding dent removal work on Ti?
I tried to freeze an fmf mega bomb, it didn't work, it started to leak at the welds and didn't pop, I got scared and pulled it out of the freezer, same technique has worked on other pipes.
It was leaking in the welds inside the megabomb
You can't really freeze the U part without putting water in the megabomb because it won't build pressure, it just expands upward.
Thinking of cutting off the megabomb, so I can plug the U part, and putting a slip joint over the cut section
It probably will work. What do you have to lose? I have done 2 stroke expansion chambers with success. I have split one. I took it to the local welding shop, and got it stitched up for 15 bucks. Way cheaper than a new pipe
