crf450 smoke
I have a2008 crf450 and when I first start it puts out a lil smoke but once it gets warmed up to operating temp it dosnt do it all anymore . and it has a newer top end on it with new valveseals piston rings etc. is this normal for crfs
Sounds like the rings aren't seated properly (cylinder out or spec and/or not properly prepped prior to installing the new piston OR improper break-in procedure) or leaking valve stem seals.
Mine doesn't smoke at all. Puff on startup is typically valve stem seal.
