My 2013 CRF250R does not run on idle and misfires at low rpms!
Hi,
My 2013 CRF250R with 11 hours on the clock does not run as it should.
If i don't hold a bit of throttle, the engine dies.
I also notice that on lower rpms i runs really rough (pops).
My suspicion is that the fuel filter is clogged.
Has anyone else had the same problem?
And just to make my day; I found that the rear shock is leaking for the second time.
I've never been so unfortunate with a new bike ever.
Please try to help me out!
Jon
Have you tried adjusting the fuel screw (I forget what it's called on the EFI machines)?
When I got my 2012 it was idleing really low, even stalled a couple of times.
couple of quarter-turns and it was running smoothly. I think you turn counter-clockwise to speed up the idle.
I wish it was the idle screw, but it's not.
I've only adjusted that once after it's break-in.
I did try it earlier today with no result.(at the track, when the problem occurred)
If I let of the throttle at about 3-5000 rpm the rpms drops and the engine stalls.
